ssnjrthgr8
ES4 with star lines and eq solved the issue
China is relatively cheaper in PC parts. Taiwan too
I have titan V and threadripper and I live in India
You are rich AF dude...
@HungryPanda
Europe is dAmm expensive
How did you get it down to $49? Even with store coupons, the lowest I'm seeing is $59.
i guess because of my ears. I had otitis(ear issue)especially my right ear. And every my earphones has distortion(crackling, sizzling noise) on right side. But when i try the left side of earphone into my right ear than it happens again. Heck i cannot enjoy musicLike another poster suggested, swap the earpieces left to right and right to left. Does the problem follow the earpieces, or is it your ears? If it is your ears, maybe your ears are different sizes, and you are getting a better seal on the left side?
N
NO it doesnt. Only sometimes
I have same issue with new pairSo today my KZ ES4, ZS3 & ATE arrived ... took them just about 5 years (cough).
The ZS3 is a real bass-monster (not my kind of iem) but also some harsh heights? Or is it just my imagination ... ?!
The ES4 is somewhat louder on the right side (maybe the cable) will check it later ... the zs3 cable should fit, right?
The ATE is surprisingly my favorite so far ...
I'll try them some more later
I have both ES4 and ZS3 and find that ES4 has more bass than ZS3. Are you hearing the same? I'm personally feeling a lack of bass on my ZS3, or I'm looking at it the wrong way.So today my KZ ES4, ZS3 & ATE arrived ... took them just about 5 years (cough).
I don't think it's the cable. I have both stock and silver, both sounds the same on both sides, so I don't think mine's defective.I'll test it later could also be a faulty cable~
