mbwilson111
- Oct 13, 2016
imagine KZ making on-ear and over-ear headphones lol
I think they did.
Set the volume in device to near max, fiddling the BT volume, no change.
I buy it from reseller in my country, it only cost about 10USD. I doubt this fake, because the packaging & unit seems legit and looks exactly like in gearbest etc. also the device recognizing it as KZ.
**** i never knew lol
The quality difference really is dependent on a few things.
i) The data rate being sent.
If you're doing 256kbps MP3 (which is decent though not the best of course), then you probably won't get much fidelity loss from "lossy compression"of the BT data packet. But if you were running a 750kbps FLAC file, the compression and thus data loss effects will be more obvious.
I have a BT 5.0 receiver that I connect to my desktop DAC. The differences in sound output are quite evident the higher the input data rate is as I have actually done A/B testing by switching inputs while listening.
ii) How well the module can drive your IEMs.
Some sound better with more power, so not much if noticeable difference. Case in point being the Tin Audio T2 and the ZS10. The former doesn't sound much different with amping or without. The ZS10 does sound different with amping, hence a more powerful input source can influence positively or negatively an IEMs sound.
Does yours look like this one?
https://www.aliexpress.com/item/New...f4ae85f&transAbTest=ae803_2&priceBeautifyAB=0
or this one?
https://www.aliexpress.com/item/201...81f46c8&transAbTest=ae803_2&priceBeautifyAB=0
Have you also tried them on a smartphone? Which music program do you use? If Spotify, please select Extreme audio quality. There are a lot of factors.I'm burning in some headphones right now and I'm hard-pressed to tell which ones are better than which. They virtually almost all the sound the same. It makes me realize buying $400 in budget headphones was a bad idea.
I'm using a Zishan Z1 with a Fairchild NE5532 opamp to test and so far the results are: KZ ATR, JBL Synchros E10 (they may be better but they always fall out of my ears, I guess I should try foams?), Rock Zircon, Old KZ with blue cable/Knowledge Zenith on plug, KZ ED7. I also tried KZ ZS3 but I forgot where they go.
To be honest with you all the headphones sound good and there are really only a few nuances that change each from the other. I guess with them maybe using similar factories or parts budget headphones don't really stand out.
Which music or opamp should I use to test which pair of headphones is better?
The reason I ask is I want to buy a KZ ES4 but it sounds like a waste of money since all the headphones are basically the same.
I swapped my Muses8920 for a NE5532 op amp on a DIY'ed aliex dac/amp and the resolution became worse with more noise.. Maybe muses8920 might help you, or if you can spend more maybe the muses 01/02. Best is to check the opamp threadI'm burning in some headphones right now and I'm hard-pressed to tell which ones are better than which. They virtually almost all the sound the same. It makes me realize buying $400 in budget headphones was a bad idea.
* Which music or opamp should I use to test which pair of headphones is better?
** The reason I ask is I want to buy a KZ ES4 but it sounds like a waste of money since all the headphones are basically the same.
I'll never use a smartphone to listen to music so I don't see the point of testing these headphones on one. I'm really old school. I prefer a portable music player. The ones I have are Colorfly C3, Benjie S5, Zishan Z1, Zishan Z3, Walnut v2.2 and Walnut V2S.Have you also tried them on a smartphone? Which music program do you use? If Spotify, please select Extreme audio quality. There are a lot of factors.
Actually @audionab discovered it, and I was the one who used it in the beginning.Started exploring different ways to EQ the ZS10 to make up for some of its flaws and stumbled across an Android app by the name of Neutralizer. I think it's really smart with these since you're basically using your ears to level-match different tones or cancel out anything too bright/boomy. Aiming for something as volume-matched across the range has definitely tamed the hell out of these things, brought the mids to a more even plane, and just overall made them more enjoyable. I added in a photo of the resulting curve; keep in mind that I'm using the silver-plated cable.
Burson v6 vivid...try this op ampI'm burning in some headphones right now and I'm hard-pressed to tell which ones are better than which. They virtually almost all the sound the same. It makes me realize buying $400 in budget headphones was a bad idea.
** The reason I ask is I want to buy a KZ ES4 but it sounds like a waste of money since all these headphones sound basically the same.
