Slater
Thanks for the detailed reply. What's the easiest way to cut off the plastic tips?
I use an Xacto (hobby) knife. The plastic is really soft. You just cut it off even with the aluminum top as a guide. It all comes off in 1 chunk.
And the nice thing is that you can also use the point of the Xacto knife to scratch in the mark where the rounded part of the plug normally goes. I scratch the little mark in the aluminum, because a sharpie would just rub off. I put my marks in that top (smooth) section of each aluminum plug.
You can see a good shot of what you trim off here (it's all of the whitish plastic part at the end):
And after you cut it off (apparently I did kind of a sloppy job when zoomed in this extreme):
