bsoplinger
I assume you've tried the included KZ Starline tips. You got 3 pairs total, M already on the ZS6 shell and a S and L in a plastic pouch. The KZ Starline L aren't as noticeably larger than the M compared to other brands ear tips but if you put them side by side you can see that the body of the L is more bulbous and does indeed take up more room in the ear.…
Just a question if I may..
Does anybody knows where to find some XL eartips that fits my ZS6? I really don't like foam, never tried gel. the best would be 14mm or more... My ear canal is apparently like Falcon heavy stage one.
Hope this helps, and thanks for any help for my tips!
V
If those are too small you may have to go with foamies to get a decent seal. About the only larger size I know about but have never actually seen are the JVC Spiral Dot ones. And those basically require ordering then shipping from Japan. There are a few sellers on Amazon and eBay that order in a lot and sell them for more than the direct from Japan price but usually not too much more. But they come in 5 or 6 sizes so the more quickly delivered ones vary based on who knows what reason the domestic sellers chose whatever size they have.
