Otto Motor
I don't know whether the ES3 you reviewed is the same (sounding) version as mine.
Your information is just fine. It is KZ's inconsistency I am alluding to .Understood. I'll be adding more information in an edit for this very reason so check back later this evening perhaps (for the updated info).
Really cool! Is the seal tight enough or you need to put some glue around the nozzle?
Thanks for this hakuzen.Those readings in your first chart show such a wide variance, which is concerning. Clear evidence of why two different people hear two different things. Unacceptable QC!
For those of us who are older than god:
The joys of finger-painting.....
Just on a curious note; did one have a mic and the other didn't? Just wondering.Absolutely; likewise. That's the additional information I'll be focusing on. In the meantime, hakuzen's work will serve as evidence. See the following post for more insight.
I am just trying to listen to the music videos accompanying your review...many of them "are not available". Is Canada being blocked out?Absolutely; likewise. That's the additional information I'll be focusing on. In the meantime, hakuzen's work will serve as evidence. See the following post for more insight.
Also, looking at those graphs, notice how much the midrange is effected.
Just.....all over the place. I always say that small tweaks in the wrong areas can take things from pleasant to offensive without much effort.
Slater may be able to chime in on removing the foam that sits between the mesh screen and BA to open things up on your ES3. Just a thought....
.....if we find mids too forwarded or recessed, play with the foam in the nozzle (it tames the mids which come from the dynamic driver).
for the price they cost, i found them more competent (resolution, imaging, etc.) than many other hybrid iems which costed me 4x more, and i like their tonal signature. so they are a very good value, imo.
The included "starline" tips are actually quite good and highly appreciated here - I just ordered some more from aliexpress. You will have to find out for yourself whether you like comply foam tips. I personally do not, and many others don't either.
Did you, as a first step, play with the different sizes of the included tips? Do you have any other earphones the tips of which you can try out on our ZS6?
If there is a problem with the included tips, what is it?
guys how can I improve the bass of kz zs6 anyone have some suggestion for tips I cant get a good seal with kz zs6 thanks
