Dasaesthetics
- Apr 29, 2014
Easy.....the KZ-EDSE. Quality is also genuinely good!
Sweet. Where can i purchase them?
let me help you here.Sweet. Where can i purchase them?
Not sure if this has been posted here or not, I have tried to read through most of the 177 pages... but I just contacted the Official KZ Store and they say they stopped production on the R3.
What, really?..
Also, someone in the Piston thread claims the SQ of the plastic Piston is the same as the metal. The plastic Piston is also looking pretty good!
Anyone compared the KZs to the then famous ´Focalprice cheapies´ which are $4 now?
XKDUN CK-700. I still have a pair, like them a lot. Now I have the MEP-933 for on the road I dont use them a lot anymore, they do isolate much more though so they still get few hours a week and yeah. Try them. Would like to know how they compare to EDSE, since I want to buy a spare CK-700 but if the EDSE is much better I might just spend a little more.
http://www.eforchina.com/view/106174/High-Performance-Noise-Isolation-Stereo-Earphone-with-Bass-function-for-MP3---MP4---iPod--CK-700--White-.htm
- I remember Wokei had those..... -
I'm not sure I'll be able to find it, but I saw a comment describing the build differences between 2.1 and Basic (plastic).
Hi wokei! Which would you prefer for classical/country ? Treble is really painful on xkdun sometimes and needs to be eqed down!
Ok, after "failing" with KZEDSE (didn`t get proper fit with any tips, cable sucked for me to wear over ear, they moved in ear due to small shape (diameter) and stuck too far out of the ear, littlebit heavy)...
And more about KZEDSE - another guy from local PC forum claims that EDSE quality is inconsistent... one had more bass, other was more "flat".
He bought these from aliexpress official kz flagship store with one order. So, ppl be warned - cheap price and bad quality control. Many of us in this thread
might not have same quality products and thus different impressions.
From personal experience, I ordered 2x EDSE and they sounded same. So far I have had good experience with KZ, hope it stays so.
edse cable gets softer over time in a good way. With normal use in a few weeks it will go over ear just fine.
I did use it some time, didn`t get much better. For me - not fine.
About my remove-sticker-modded KZ-R35, took a pic:
