Dark Helmet
- Feb 9, 2013
I actuall took and put some blu tac in there to steady it and it worked well. I initially put some super glue in there as well.Yes, I do unfortunately.
Yes. Listening to them as I type. They fit snug.Despite the triple braid not fitting the ZS6 perfectly, do you find it to be connected adequately enough to not be bothered by it?
Oh, the female side? That sounds like a QC issue, but it should be pretty easy to open them up and steady it.It's actually the plastic housing that the pins are in that moves.
Seems like you already figured that out.I actuall took and put some blu tac and put some in there to steady it and it worked well. I initially put some super glue in there as well.
Thank you for the links.That data comes from @hakuzen, the original is here:
https://www.head-fi.org/threads/kno...essions-thread.698148/page-1553#post-13777787
EDIT: oops, that's the first round of tip rolling, here's the one with Ostry tips too:
https://www.head-fi.org/threads/kno...essions-thread.698148/page-1527#post-13766425
I think they are already on Ali. I got mine from Amazon for $13.99. I think on Ali I saw them for $8 or $9.What Dark Helmet said, they do hold on very well even for shallow insertion. I'm just going to bide my time as I think with the popularity of the ZS5/6's these triple braids will eventually make it into the hands of the AliEx sellers.
Nice tip, will try that out and fix my loose cable inserts.I actuall took and put some blu tac and put some in there to steady it and it worked well. I initially put some super glue in there as well.
A little blu tac goes a long way.Nice tip, will try that out and fix my loose cable inserts.
Can you compare them to the ZS3?
At 26$ even with 11.11 it's relatively expensive f they are not that great.
Any other new KZ with memory wires since the ZS3?
Not specifically, but they do say it will work on the ZS6, and that's what I'm using.Specifically the Type A for ZS5/6? Need that link
This is probably the design of the ZSR PRO.
As you can see I have that new ZS6 platinum colored cable on my ZS6 in this picture however it's sounds veiled to my in comparison, same goes for the silver and gold ZS5 upgrade cables. Fortunately the ZST braided cable works with not only ZST's but ZS6 and ZS5 even though on the five the pin housing will not drop all the way into the slot it catches enough pin to hold and sound great.
