Fox2twenty
Formerly known as iPhone IEM
This is blowing my mind... Now I want a heavy cable!!Well if your cable is heavy enough there is no need for wire wrap
I got this KZ cable today. It fits ZS5 very well. The build is very good. The Y split and 3.5mm jack are big with good quality.
But it's very heavy, weight 20g compare to 12g of original ZS5 silver cable. And with ZS6, the total will probably be 40g.
I think the first couple of people who posted got bad sets and we ended up with good ones.ZS6 arrived via GB coupla days back.
great news, off da bat, NOT treble cannons.
sounds a lot like the ZS5v1 but with more air.
loving it so far after 2 days of burn-in.
@VinceHill24 thanks for your impressions
Sounds like the ZS6 could suit me, I like treble and as long as the bass isn't too much these could be a win.
If you have fear for that and are not in the mood for mod them and try different tips for bass enhancing, it's best to wait until some more treble sensitive guys receive the normal cannonHuh!? Interesting. I might consider ordering a pair then. That still means that they're bright sounding though?
Searching around i have see something that it could be related. Here, this guy write that the ZS5 have a maximum input power of 109 mW, and the ZS6 of 75 mW.one more thing of note, the zs6 is more picky on source and amping than the zs5v1. feed it junk and the nasties will show up easily. the zs5v1 is way more forgiving with lesser quality audio.
For those who have purchased the ZS6 and want to trim treble, there are some Ostry tuning tips, the OS300 are the black ones, maybe can filter some treble peaks:
https://es.aliexpress.com/item/OSTR...108.1000016.1.15437274TukNpk&isOrigTitle=true
I have them and I use them to filter trebles peaks in my RHA S500, at 8KHz (not bigger than ZS6).
https://www.innerfidelity.com/images/RHAS500i.pdf
There are no problem to put this tips in my ZS5.
Probably there is not the best solution to filter this Everest peak at 10KHz but they can help a little.
Oh please... like someone can think that with 8$, for an upgrade KZ cable, we can buy something with electrical characteristics good as the ones that cost a bunch of ZS6I suppose you really don't know what you are buying
