bertwong
- Dec 2, 2014
No he means on those tubes on which ear tips go. Do they have a vent?
Yes. I got one pair of black and one pair of red
Yes,you are correct, they are the removable nozzles but like in the picture, all those black and red nozzles have the vent?......
yes both have the vent. Didn't test the difference yet.
I got my KZ EDSE and KZ GR. Thanks for everyone who comment about these IEM. EDSE and GR has different sound signature. The EDSE came with some greasy spot. I really like EDSE which is similar to my KZ IE80. Very bright and neutral. Vocal is the best part of EDSE.
KZ GR seems so powerful and quite artificial. It is not my cup of tea maybe I didn't run in. It's really heavy, heavier then my CKM99. I changed the filter and found that the eartips are not fit at all. Compare with IM50 and KZ GR I would prefer IM50.
How's the bass on them?
properly don't go for EDSE. The sound is netural similar to SE215 or BA driver. GR is much better than EDSE but seems too aggressive for me. Didn't try the black nozzles so much. The bass is too strong for me. After run in around 6-8 hours the GR the bass seems soften a bit. GR is funny although I prefer EDSE.
How are the kz-lps in terms of bass and vocals and soundstage?
