ricemanhk
- Jun 23, 2014
So I'm actually a bit concerned with this Bluetooth cable. No matter how many times I plug it in, it continues to charge, eventually changing the light to blue indicating it's done charging. If you plug it in after that, it will charge for another 45 minutes. May be a small fire hazard, keep an eye on them!
Yeah I wouldn't keep charging them to full like that...you never know. Does anyone have a USB voltage/current meter to check how much current it's pulling when charging? Maybe it's just super slow trickle charging after it gets over 80%.
BTW I have no issues with interference with mine and I live in Hong Kong...I pair it with my xiaomi mi5 phone. That said, range is not the best if there's no line of sight, but I guess you're meant to keep your phone near you when using BT headphones so it's ok.
Both my box and manual says 4.2 and I get at least 2h battery life (haven't done the full 100% to 0 test yet) so I should have the newer version. And indeed sound quality is better than I expected for BT. With the ZST it beats the pants off of all my other BT headphones haha
I might get the ZS3/ZS5 one later if I upgrade to a phone with no headphone jack (what are the OEMs thinking...)
