wastan
- Jun 13, 2015
I'm late to the ZS3 mod but i have to say slater's mod really does make a difference in my ZS3. Previously the bass was a bit too intense, boomy and a bit of bloat. Treble extension is there but is more laidback. After the mod, it seems to be attenuating some of the bass response resulting in lesser midbass, much more controlled with less to almost no bleed into midrange. The treble response seems to be accentuated by a little making them little more forward and the overall presentation is no longer dark but kinda sacrificing its previously smooth qualities. I don't think it'll be a good mod for treble sensitive user who's already enjoying ZS3 in its own.
I've replaced the red screen with a metal screen coz while removing the screen i kinda damaged it in the process, gotta protect inner driver from earwax so having a screen definitely improves usage span.
For ZST, i don't think i'll do the mod as it wasn't that ear hurtingly bright to me and i tend to agree with Coil about using dampening filters for the BA as it would result in better consistency and of course lesser chance of damage to the driver itself as we never know when would the cotton just drop in all the way into the inner workings of the BA driver that could possibly risk damaging its inner components. But it'd be a cost effective try anyway + ZST is not that expensive so if its value doesn't bother you much it ain't gonna hurt trying.
Personally i found foam tips helps tame down the brightness of ZST so i think it'd be great to give foam tips a try 1st.
Where did you get the screen?
