Just got a review set of the Freya.
Beautiful hand painted shell, it is huge though, slightly larger than my Audiosense T800, but quite comfortable and surprisingly very very light.
So OOTB, testing it with a Tempotec Sonata HD Pro:
- I would describe the Kinera Freya as having a balanced mild U shaped sound, with slight boosts in midbass and upper mids/lower treble.
- Bass is very well textured and accurate, with minimal midbass bleed, the subbass rumble is quite good like in well tuned DD sets, but subbass extension is not the deepest. Midbass is of more quantity than subbass, with bass north of neutral, but not at true basshead levels.
- Lower mids are very mildly recessed, but still detailed, with good timbre for a hybrid. From the specs sheet, the Freya uses some Knowles BA for the mids and it does indeed sound well rounded and clean, typical of the Knowles timbre. Note weight is moderate.
- Upper mids and lower treble are boosted slightly but within my tolerances and is not harsh unlike some CHIFI counterparts.
- Upper treble extends quite well and is not too fatiguing (I'm treble sensitive), and sibilance is mild.
- Technicalities are very good for imaging, clarity, instrument separation and details. Soundstage is quite big.
Will do some serious A/B testing with some midfi CHIFI sets, but offhand, it for sure trumps all my midfi Westones that cost more. I think the Audiosense T800 (8 knowles BA) edges the Freya slightly in the technicalities department, though Audiosense T800 is much brighter and more fatiguing for longer sessions. The Kinera Freya is more laid back in tuning, with lesser troughs/peaks in the tuning than the T800. TRI I3 perhaps has a bigger soundstage but has less clarity and details than the Freya, and TRI I3 needs amping to sound good due to the planars inside, whereas Freya is much easier to drive.
I don't give two hoots about how an IEM's looks as long as it sounds good (the Freya is very beautiful though). But I'm pleased the Freya's sound quality internally is as good as the external appearance!
