There is not enough power to power the T2P. When I connect it to Mate 40 Pro, there is enough power to power the T2P but sound came out of the phone speaker instead
Hi @captblaze
Glad to know you've got your T2P on hand and seems that you are the 1st one post on the public
T2P with ~500mA / 5V power consumption and maximum at 620mA while playing PCM 768 songs, so your Android Phone or PC can drive T2P directly and any 5W power supply will work.
We not suggest to use a phone charging adapter as many phone charger is quite noisey and it will not help for the sound(help for the battery life of your phone).
I wish I had my order in my hand, but alas it hasn't shipped yet. I am patiently waiting the next batch release in hopes my order has made it to shipping. My questions are to have things ready for the day I do receive my Tone2 Pro
I am very puzzled with using the volume knob for it's different functions. Felt that it's not very intuitive. I guess I might sell it unless someone knows of a video tutorial which I can see.
I don't have my Tone 2 Pro yet, but I too have a question on the knob's operation. If I want to adjust volume, I push twice first? Would it stay in volume mode? From volume mode, what if I immediately want to go to Gain Mode? What do I do?
It's pretty simple guys but yes, it's unintuitive at first. The LED patterns indicate the modes/functions so you have to refer to the manual for that. Cycling via pushing downwards twice on top of the wheel itself (not surface) indicated by mild clicks. Then turning the wheel adjusts the levels.
@KHADAS
DAC output impedance is 200k ohms balanced, 100k ohms SE. It is much higher than the input impedance of, say, the Drop THX 789, which is 50k ohms. Will this not have a negative effect, like a voltage divider?
I can't hear the DSD files , the color is correct, but I can't hear anything, not on Roon, not on Audirvana
How to fix it? .. if it doesn't work, I'll have to return it
I use Mac os Big Sur.
I've never had a problem with Dac ..
DSD Over PCM 1.0
Do you happen to know if Anker chargers also work well? For charging purposes, they're usually regarded as more premium and higher quality than Apple chargers. I'm not sure if the same applies to audio performance though.
