LostnAmerica
Wow! Incredible ingenuity and workmanship.
This is the original GH50JM Mk1 Edition Interior- and what makes the GH50 so unique and so ripe for further modification....
Why the Kennerton GH50 is so awesome - it's design is ripe for the ultimate transformation - and why the Mk2 will never be a manufactured item -as an example this the back plate that has a tapper to it and inside that tapper is where I remove the cellulose foam and replace it with hard dense carpet in the center and a hard wave nylon pattern by 3M®- and then I top that off with a fiberglass fractal pattern of mesh and then I top that mesh with a resonator which is also non magnetic and that gets topped with more fiberglass fractal patterns of mesh (so two layers of 4 layers each) then that butts up against the driver rear facing magnet center and captures the back pressure sound waves and the non magnetic resonator reflects the higher frequencies back into the oval cup seen here- there are a total of four layers of four layers of separate fractal fiberglass mesh for the sound to slow down and act like a huge interior while still maintaining its exact locations. Pin point locations of the recording to be precise. I know the design is over the top obsessed and nutty looking but the proof is it works...
I say it again, this time backwards. Wow!
