I have the Kennerton Litz 4 pin XLR balanced cable and have a ZMF Verite which will be here soon. Will the Kennerton balanced cable work with ZMF?
thanks
thanks
That is just who Ray is. I have known Ray from soon after he got into business. I met him at a Chicago Head-Fi meet. I have his Apache and can attest it goes well with the Thekk and my Utopia. It is probably 95% there for being able to drive even my HE-6 but he created the Dark Star basically for the headphones like the HE-6. I hope you enjoy the Apache. I currently have his latest OPAs in mine but I have been torn between them and the Sparkos Labs S3601. You have two choices for you headphones, either buy new headphone cables terminated in the dual 3 pin XLR or buy a quality adapter. I use a WyWires adapter as both my Thekk and Utopia have WyWires 4 pin XLR Platinum cables..... The Apache is OPA based swappable but you need 4 LOL! - And as I understand it the Apache has gobs of power so difference will be met with tons of dynamic power................................ Ray Samuel promised if I want to upgrade the amp to best of best ever offered by him it would only cost $100. LMAO I thought he said $1000. Nope- he really said $100. I told him let me get hold of that pretty beast first and then I can decide... I am hoping it is better than my WHAMMY. I know the Beta22 has a good rep for class A but its no where close to the build that is by Ray Samuel and his service is nuts! He said free upgrades on my amp that I bought used! WHAT? How does that work? Who is this guy Ray Samuel and how can he afford that?..............
Awesome review informative and spoken eloquently... “The Kennerton Magni is a tasty delight, with all the clarity and detail, soundstage and musicality of a world class transducer. All wrapped in the loveliest of aesthetics. Magni is a technical and artistic marvel, and I highly recommend it. If you have ears, I suspect they’ll suit you nicely.”
Agreed. An enjoyable and enthusiastic review.Awesome review informative and spoken eloquently... “The Kennerton Magni is a tasty delight, with all the clarity and detail, soundstage and musicality of a world class transducer. All wrapped in the loveliest of aesthetics. Magni is a technical and artistic marvel, and I highly recommend it. If you have ears, I suspect they’ll suit you nicely.”
Good read. Never thought of them as being designed as portables though. Easy to drive but the design don´t appear to be meant for that purpose. Being ported they leak so not sure about office or library use either so they should be greatful for the great sound lol
You get the littlest if feedback through the bass port but other then that they are quite silent from the outside. I let them burn in for a few days at moderate to high volumes and I heard almost nothing standing next to them (while the cups had a good deal on the stand).Good read. Never thought of them as being designed as portables though. Easy to drive but the design don´t appear to be meant for that purpose. Being ported they leak so not sure about office or library use either so they should be greatful for the great sound lol
