Before you read this, let me just say that the differences I noted were not earth-shattering. They were subtle, but spread over a number of areas so that the holistic sound was quite distinct between the two headphones.
The K1000 failed to render spatial cues that the HD800 could. IMO, the latter's soundstage is more recording-dependent. It can scale from relatively small to absolutely huge (quite a bit larger than the K1000). The Senns also produce a more enveloping and layered stage, filled with more microdetail. What makes the K1000s special is the complete physical separation and distancing of drivers as well as the natural crossfeed from channel mixing. This gives them a special open, speaker-like quality. However, as a transducer reproducing the space of the recording, the K1000 is significantly behind the HD800. Put another way, the K1K's presentation is almost like a wall of sound in comparison.
There are a bunch of things really which I don't have the time to delve into. Microdetail, soundstage layering, nuance, microdynamics, frequency extension...just some of the areas where there's a noticeable difference between the 800 and K1K.
The HE6, LCD2, and in some ways the T1 and SRH1840 surpass the K1000 in several areas I mentioned. But, to me, it was most apparent when comparing to the HD800.
Mike on headfonia went overboard with his criticism of the K1000 no doubt, but if you water down some of his arguments, I personally think there's some truth to them. Although, I didn't have nearly as much problems with the tone as he did, especially since I got mine recabled.
Of note, mine were the bass-heavy pair. I've never heard the bass-light version. Speaking of which, I felt mine had amazing bass punch that trumped all my other cans. Their sound was also very direct, energetic and fast with world-class macrodynamics. Again, in these specific areas, they were among the best IMO.
