Own JVC LIVEBEAT SYSTEM earphones that combines high-resolution in the treble and realistic bass that the woofer mounted in the inner ear, the idea ever. The secret is in the exquisite combination of stream of a newly developed woofer and tuned twin system unit dedicated to the HA-FXZ series. I did not realize the sound experience to highlight the whole range that has been difficult up to now by a combination of stream woofer to reproduce deep bass and realistic twin system unit that is responsible for the smooth treble.
Equipped with a newly developed woofer stream earbuds for the first time in the industry. Applying the method of speaker technology Kelton, covered with a brass base unit woofer unit, forming a sealed acoustic structure, the combined stream elongated duct there.
The sound from the woofer unit, we were able to more than 100Hz are attenuated by passing through the duct in the stream, to extract only pure bass components. Less impact on midrange to reproduce realistic heavy bass.
The silver cable "for higher resolution across the entire frequency range" and brass case unit in the FXZ200 seems the way to go. The FXZ100 sounds like a step up from the FXT90 but the 200 seems to go the extra mile
Time to find something more to read on the Kelton speaker tech, lol.
BTW, it says the twin system is uniquely tuned for the FXZ so not quite the same as in the FXT90.
