surfgeorge
Member of the Trade: 3D Printed Accessory Designer
@DimitriSF
I'd be curious to hear the modified FD01 with the mod as described by @james444 !
Cables...
Yes, it could be as you said that the reduced impedance increases the volume and therefore sounds different.
But I for one am convinced that there's more to it. Back in the days when my friends and I were building our stereo systems we got the basics down and then started looking at cables.
One of my friends had built a system based on designs and components from "Clockwork Orange" a German Hifi company that offered kits of extremely high quality and tuned commercial SACD players. His system is awesome.
My friend has a masters degree in electronics and he did not believe that cables could make an appreciable difference beyond their resistance and capacitance values (I guess, I'm mechanical engineer). But his trusted contact from Clockwork Orange just sent him a set of cables, and they clearly made a difference.
I can hear differences, both in speaker cables as well as in signal cables between DAC and Amp. So I am a "believer" if you like.
And there are even mathematical explanations which go far beyond current, voltage, resistance and impedance.
I also believe that the ear and brain are much more capable than the general 20-20000 Hz hearing range describes.
Think about the information we get from what we hear. Direction, distance, etc.
But to come to a conclusion, I would have to go back and do A/B comparison with the stock cable (which is worse on the FD02 compared to the FD01)
I don't really like that because the MMCX cables feel a bit fragile, but maybe I'll do it some day.
I was quite certain that I heard a difference in the shop, changing a few times between the cables. Certain enough to spend €100.
But I am sure I know plenty of people who would not hear a difference. It's a specific kind of listening. Nothing obvious on the surface usually, like the difference between a perfect stroke on a violin and a slightly off one.
Too much rambling
If you don't hear it maybe the fD01 cable is good enough, and then you saved yourself some money for other IEMs!
Cheers
Cables...
Too much rambling
Cheers
