well for me the important thing is how it sounds,
You’re joking? The signal in an Ethernet cable is in the high hundreds of megahertz, there is no “how it sounds”, no speakers/HPs can reproduce it and it’s miles beyond the limitations of human hearing anyway.
with many audiophile claims/myths it suprised me subjectivists 80% of the time actually have a point
What 80% of subjectivists and how are you surprised by a fact/figure that you yourself just made-up?
so i got to the conclusion that trusting what you hear is more important than what some people claim, even if they come from a scientific perspective
Firstly, thanks for demonstrating yet again what castleofargh clearly explained, you’re again basing your “conclusion” on a fallacy, the Argumentum ad Populam Fallacy and even more impressively, you’ve simply made-up the level of popularity! That’s funny.
Secondly, you keep going on about what “you hear”, how you trust your hearing and that it’s “
more important” but clearly that is a LIE! If it really were “
more important” then you would have tried to actually identify what “you hear” but you haven’t bothered. The actual truth is that you don’t care at all what “you hear”, you don’t trust your hearing and it is not “
more important” to you! The ONLY thing that’s important to you is what you think you’re experiencing, regardless of whether you’re actually hearing any difference or it’s just a figment of your imagination.
also back to the ground/shielding question
1. galvanic isolation can let noise trough, as the measurements from alphaaudio show
2. i have a hard time to understand that even if the datalines apply CMR that the noise will actually be reduced below the noise level of the switch itself
1. Another lie and you know you’re lying because it’s already been explained to you! Again, the measurements from alpha-audio were of the output signal, they did NOT measure the signal after the receiving port and isolation and therefore your assertion is FALSE, the measurements did NOT show that galvanic isolation can let noise through because they did not measure that!
2. There we have it “out of your own mouth”! There really is no issue with noise, the issue is entirely that you “
have a hard time to understand”, which is surprising because as mentioned several times, it’s not hard to understand! Maybe you can explain how a shielded cable can reduce “
the noise level of the switch itself”? Not without more made-up nonsense or marketing BS you can’t. What CMR drastically reduces is any noise/interference added after the differential signal is created.
Your points here are self contradictory. You showed evidence there’s a relatively high amount of noise (on the port output) but you also admit that it must be removed, otherwise the noise would sum from successive switches/routers and the internet simply wouldn’t work. So how do you think that noise is removed, if it isn’t from the use of data buffers, galvanic isolation and CMR? You think maybe the all the world’s Ethernet switches have been infused with audiophile magic?
i never said data integrity is a issue, since the internet wouldnt work otherwise... noise at those level i speak about just seem to matter in audio tho
What noise at what level? There isn’t any Ethernet noise at the DAC output, so how can no noise “
seem to matter in audio”? Obviously it can’t matter to audio, although clearly it does matter to audiophile marketing!
IF noise is really the culprit here, which i cant say for sure but its the next logical thing after data integrity
As the noise is removed by galvanic isolation, CMR and data buffering, how on earth is noise “
the next logical thing”? Noise is obviously the least logical thing and you’re yet again demonstrating you aren’t capable of logical reasoning!
and for me, since people are hearing a difference there must be some reason for it...
Firstly, what people are hearing a difference? There are quite a few people who claim to hear a difference but I’ve not heard of even one single person who has reliably demonstrated the ability to actually hear a difference, despite audio being transferred over ethernet for about 30 years! Why do you think that is? So the question really is: Why are some people claiming to hear a difference? There is “
some reason for it”, a proven reason that’s very well established, well studied and has been consistently demonstrated for a century or so!
and i should probably also say, if all im hearing is placebo, then its a pretty trippy placbo, consistent over weeks and months if i dont change my setup
So you don’t even know the basics of perception errors (placebo) but are nevertheless willing to argue and make false claims/assertions about them, even in an actual sound science forum? Astounding!
Some perception errors/biases affect virtually everyone and last a lifetime, the stereo/soundstage effect being an obvious example. Others just last a few moments, only affect a percentage of people and/or are inconsistent. You really should learn the basics, not just of perceptual errors but of Ethernet and audio in general BEFORE you start making assertions and arguing about it, because that ONLY demonstrates ignorance and foolishness!!
G
