Ghoostknight
i think cat 6 is quite common too, (and unsure of the ethernet implementation of music streamers for example) so maybe some changes people are hearing are just because the shield of the ethernet cable is connected to the receiving deviceStandard Ethernet 10/100/1000 megabit (and even 2.5Gb up to 10Gb in many cases) uses UTP cat 5 cable. That’s Unshielded, Twisted Pair cable. That pair of wires carries the two differential data signals. So by definition, the output of an Ethernet switch MUST be ground/shield isolated from the downstream receiving Ethernet port because there is no ground/shield connection, unless of course you think the ground/shield is somehow magically travelling between Ethernet devices though the air or some audiophile 5th dimension?!
and im still unsure about the middle-points of the galvanic isolation on the input side connected to ground... and effectiveness of the galvanic isolation to noise, a transformer should transfer noise just fine, maybe a bit attentuated...
well no, i didnt think about POE, tho on shielded cat6 cables the shield is still connected to groundOh dear, the image you posted appears to show a schematic of the protection employed for POE (Power Over Ethernet). So NONE of your post was relevant to Ethernet, unless you’ve got a POE switch/router, a DAC, streamer or computer which is powered over Ethernet and the POE protection doesn’t work properly! Was that just an inadvertent error or a deliberate attempt to mislead? Hmmm.
