redrol
Well ok then, lets start an IEM cable company.
Also the owner of that company posted he was going to sue me right after I posted that, then when a ton of comments were laughing at him, he deleted it all and vanished
How does noise that doesn’t exist and is therefore not noise “still seem to matter”? Or are you saying it’s magical audiophile noise that travels through some unknown dimension from some undefined “mid-point” in an Ethernet switch straight to your speakers or HPs and thereby bypasses the data buffers, galvanic isolation and DAC output? Presumably audiophile Ethernet switches employ some sort of anti-dimensional force field and therefore stops this noise, that only audiophiles sensitive to extra-dimensional noise can hear (when they’re not being blind tested) from travelling to you speakers?i know it cant be measured in the dac output, tho it still seems to matter
That’s another reason it must be magical audiophile noise that travels through a 5th dimension, so it isn’t subject to the time dimension and it doesn’t matter if Ethernet is real time or not!And eventough looks real time, it isn’t and never will.
I invite @Ghoostknight to take this test and decide how much he is actually hearing:
https://www.klippel.de/listeningtest/?v=3
gregorio, you are great at making other opinions look foolish +1How does noise that doesn’t exist and is therefore not noise “still seem to matter”? Or are you saying it’s magical audiophile noise that travels through some unknown dimension from some undefined “mid-point” in an Ethernet switch straight to your speakers or HPs and thereby bypasses the data buffers, galvanic isolation and DAC output? Presumably audiophile Ethernet switches employ some sort of anti-dimensional force field and therefore stops this noise, that only audiophiles sensitive to extra-dimensional noise can hear (when they’re not being blind tested) from travelling to you speakers?
Why didn’t you just say that to start with, we could have avoided pages of nonsense and gone straight to the logical, real facts!
The problem with audiophile BS is that there obviously is no reliable evidence to support it, so you’ve got to make-up ever more ridiculous nonsense to try and explain/justify it and eventually reach a point where it’s just so ridiculous you’ve even gone past the point of it just being laughable!
i wonder what studys find out is the audible threshold
i got confused between what is distorted and what not
well, then show me those studys and how it was testedMany (emphasis on MANY) show the audible threshold as -80db.
becaust some of them perform -objectivly- better than othersIf you can't tell what is distorted and what is not, how can you comment on what performs better (fancy switch)?
tho it was my "first!" test and i already have better results than 90% as it seems...-33db (your result) is quite poor.
could you guys stop turning around what i actually said?But your argument this entire time has been that since we can't objectively measure a meaningful difference, we have to rely on our ears (subjectivism).
maybe? probably? tho i never said thats whats best (cost/performance wise)Please buy the most expensive switch you can find. I 100% guarantee you that you will hear an improvement in your system.
If there were actual audible differences it could be proven with a simple null test yet no one can provide a valid null test that proves an audible difference.one thing i also noticed more than once, there are actual differences, that objectively are better but objectivists keep claiming its not audible as soon as something like this comes up, while others are actually hearing differences that could be explained this way, this is probably the real culprit
