bigshot
The chesky discs I’ve heard weren’t that great.
True but any music is way less complex than say white noise. So, you’ve got the same argument against any piece of music vs white noise as you have against a 1kHz sine wave vs a piece of music. If lack of complexity is the argument then a multi-tone (30) test signal is better or white (or pink) noise or a sine sweep.As I said above, any music is way more complex than a 1K sine.
Of what speaker? Obviously everyone would have to have exactly the same speaker because otherwise you could never compare measurements (as Castle mentioned) but in addition:What I propose is measuring the output of the amp at the speaker terminals as usual but with the speaker connected (measurement leads are in parallel to transducer).
And now we start, you presumably have no reliable evidence or facts to support your argument, so you resort to a fallacious argument. You’re claiming “all of us guy’s logic” must be faulty on the basis of an illogical assertion you yourself have invented and falsely attributed it us? What we’ve actually stated is that all measurements are not useless and are not swamped by the transducers own distortion/noise because we take many measurements without using any transducers. You are the one arguing that measurements be taken with transducers, not us! How does the distortion of transducers swamp the measurements of say a DAC or an amp if there is no transducer in the measurement chain?By all of you guy's logic we can deduce that all measurements are useless since the transducer's own distortion swamps everything else. So why bother measuring anything other than speakers?
What indeed is the missing variable and how should we address this question?All I'm saying is, I have multiple amps who's measurements show differences below the threshold of audibility yet they sound different (on the same speakers/headphones). Therefore the measurements are incomplete. What't the missing variable? The transducer.
There is a body of evidence, compiled over many decades, which strongly supports the use of test signals and loads and mind you not all of these signal tests are simple pure tones like sine waves but actually very complex test signals covering the entire audio frequency spectrum that are actually far more challenging than any piece of music could ever be. We have a sound understanding on how test "simulated" resistive and reactive loads will affect audio amp performance especially in comparison to reactive loads or even real loads (there is actually a difference between the two, reactive and real loads in the testing world). Reactive loads in themselves are not necessarily any better or worse than resistive loads in most scenarios nor are reactive loads always directly applicable to (performing the same as) real loads... but we do know enough to easily compare and interpret any of these results between any of them therefore drawing rock solid conclusions from them. Why would we therefore over complicate the matter by using real loads loads and music?You're missing the whole point. I'll spell it out for you:
Currently measurements on amps are done with a resistive load.
Speakers are not purely resistive - they are reactive.
Since nobody is measuring an amplifier's behavior with a reactive load, the measurements do not reflect reality.
Lab measurements are fine. But the equipment does not operate in a lab.
Feel free to flame me for being a subjectivist (I am not). But telling me that my point is invalid is a sign that you're either not a scientist (no interest in discovery) or you're unable to deal with variables that reflect reality.
If asking for a measurement into a real world load makes me an audiophool so be it.
"Yeah but all transducers are different and there's variance across any batch of "identical" drivers."
Yup that's the way it is. But if you use of handful of drivers consistently (high impedance driver, low impedance driver, planar, etc.) across all the DUTs, you should be fine.
At the very least to ascertain if/how they effect various amps. Maybe across all drivers, all amps will perform as their stated lab measurements. But maybe (likely) they won't. This what I'd like to know.
I thought current dialogue is about perceived noise, from noise on an ethernet cable? They're exclusive: digital mediums can have more noise in the signal but still carry more than enough data. Hearing noise in your transducer: for many applications that means you're listening too loud or have your input settings in your sound control too high.They aren't actually talking about ethernet cables any more.
Well at least in the last page it all still started with the source. Sorry, don't think anyone has tried to drive a 25watt speaker with a 250watt amp. Yes, after the digital source, there can be a subject about proper amping. But all is irrelevant to the topic of ethernet, and should we now get into all the invariable aspects of sound reproduction?I think they're talking about the best way to measure amps for speaker systems now.
No, I understand your point but I disagree with it, due to the facts of scale and due to history. I’ve dealt with scale but you don’t seem to get the pointYou're missing the whole point. I'll spell it out for you:
So you’re saying that consumer audio equipment/amps know when they’re in a lab and change their performance when they’re in an audiophile’s sitting room? What about in a recording studio, which are often similar to lab conditions?Lab measurements are fine. But the equipment does not operate in a lab.
But making up false assertions and falsely attributing them to “us guys” is scientific is it? Carver, digital modelling software and numerous other bits of history and science/engineering proves that science IS able to deal with “variables that reflect reality”.Feel free to flame me for being a subjectivist (I am not). But telling me that my point is invalid is a sign that you're either not a scientist (no interest in discovery) or you're unable to deal with variables that reflect reality.
And how do you spread that “handful of drivers” all over the world amongst those thousands of people, engineers, etc, who objectively measure amp performance? Or are you saying that the relatively large variations between drivers of the same model don’t affect the measurement of relatively minuscule audio properties? As an example, most DACs have a freq response variation throughout the 20Hz - 20kHz range of about 0.4dB. How are you going to measure those differences when using different drivers (of the same model) that have FR variations of anything from about 0.5dB - 2dB? Exactly the same DAC could measure anywhere from a 0.0dB FR variation to a 2.4dB variation depending on the production line tolerances of the same driver. You’re not actually measuring the FR of the DAC, the majority of what you’re measuring is the difference between drivers of the same model. And the scale of this problem is far larger with many other DAC performance metrics, say jitter distortion or self-noise.But if you use of handful of drivers consistently (high impedance driver, low impedance driver, planar, etc.) across all the DUTs, you should be fine.
