castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
i made similar expierences for ethernet as other audiphiles, tho i believe that its not the data itself or the internet wouldnt work as it does
i havent spent "big bucks" on switches/ethernet cables but i expierenced how the inbuilt wlan of the raspberry pi makes things worse, disabling the bt/wlan module improves sound quality and i was using a cheap d-link wlan stick for a while, i switched to a fritz.box wlan stick recently and it improved sound quality further
(also interesting to note is that i hear improvements if i underclock the raspberry pi)
the reason i use wlan is, that i think this kind of galvanic isolation is hard to achive with ethernet cables (atleast at a comparable price point) tho maybe i change my mind once i tried a good ethernet setup since the wlan stick itself can introduce noise, and maybe the fact it runs on the ghz range makes things dramatical worse
since i dont dismiss all science etc (i just think some of it is wrong, like it hasnt be discovered in "blind tests" yet, so science people dont care about it) the most logical thing (for me) is actual noise which somehow influences other stuff, even if it cant be measured on the dac output
i come from a standpoint where i hear differences first and try to find a logical explanation to kinda try to make it a "whole picture" to go from there
but the best source i came across so far which kinda line up with my current "audiophile" believes (which might be interesting to some) is the website&youtube channel "Alpha Audio"
they "kinda" blind tested (tho you guys will critique this) ethernet switches and also measured them and there was kinda big differences, for example power supply noise distributed to the ethernet ports, port to port noise isolation etc (which was surprising for me since the common explanation includes that ethernet ports are completely isolated)
https://alpha-audio.net/review/a-very-deep-dive-into-network-switches-listening-and-measuring/2/
( HOW AND WHY we test network switches... )
( Live BLIND test switches - do switches matter for audio quality? )
the blind tests on youtube where you can listen yourself is a really interesting approach but micing (tho they do a good job i think compared to other youtube videos like this) and specially youtube makes it very hard to hear differences, tho i heared some differences myself but they seem very minor in comparision if you test this yourself
Alpha Audio is actually the only really good channel i found which try to combine objective and subjective matters (which is the approach we need imo)
kinda wondering why i never found measurements like this but glad they did it, and i think they are genuine and dont try to push audiophile stuff just because the sake of it
the tests also show that they dont think the most expensive solution is the best... and also measurements show this
I feel bad criticizing the few people who put in the efforts to get somewhere, but throughout the 2 videos, I cannot help but notice inconsistencies within the guy's own rational.
We start with the assumption that maybe noise and stuff in the switch bleed into the rest of the playback chain and impact the output signal. As a hypothesis it's one I surely would consider myself, I would look for other stuff too but it's one of the potential causes that might deserve checking out.
But Then why only measure the switches? How is that ever going to tell us anything about how some DAC or streamer after it is being affected?
The blind test is... well, as the other guy said, not scientific. And not that much of a blind test when the first dude reacts and even comments before the second one has finished describing his impression.
Also the guy on the left said that it's fun. I'd add him on some government watch list just for daring say something like that about blind testing. Informative, eye opening, mostly disappointing, often a torture, I would fully understand saying that about blind testing. But fun? Never cross that guy! He's the danger.
