ljnew
- Dec 24, 2015
Hi All,
How is it compare to Westone UMPro 30? Bass? Currently I am using Onkyo DP-X1 with Pro30.
Regards
nobody
If you like the UMPro 30, I would suggest the umPro 50. I preferred the umpro50 over the Rosie overall. As far as bass goes, you might want to try the Audio-Technica ath-e70, if your looking for something in the same price range as the umpro 30. But the bass of the e70 bests the Rosie and the UM Pro 50. However you will more than likely have to search for the right tips for the e70.
On the other hand, just measuring bass for expensive headphones doesn't really make sense in my opinion. It seems like you should be looking for a well rounded iem in that price range.
