nobody7284
- Jul 14, 2015
it does not move at all
Hi all,
Anyone using the Balanced cable ? Or how many of you prefer Balanced over SE for Rosie? I try both SE and Balanced on Onkyo DP-X1 seem like slight improvement... According to one of my friend X1 from SE to Balanced the gap is very small.... Anyone can advise?
Thanks
nobody
Depends on the DAP. For example, there was a huge difference with Opus #1 DAP. Balanced out was much better.
This I agreed. I try out balanced mode in DP-X1 differences not much. Only slight clearer....
Exactly. There was a small difference with Onkyo.
So I am correct... I thought it my player or my IEM faulty...
If balanced outputs were able to make a huge difference there wouldn't be unbalanced cables. Balanced would become a standard. It's their marketing strategy.
If you want to change much more, you should temper with output impedance and power. It changes too much. Thanks to iDSD Micro I've tried a lot of combinations.
What sort of balanced termination is the extra cable that comes with them? I'm thinking of getting a portable amp/dac with a balanced output in the near future.
I have no experience with balanced headphones/IEMs though is the difference that significant, or is it hyperbole?
2.5mm TRRS with the pinout being Astell Kern. Any Astell Kern DAP will work with it as well as Onkyo DP-X1 and the AM3 module of the FIIO. There is a few more, but those are the major ones.
