Yes,
Yes there is a bass box attached it, I kind of like what I hear so far. The cable is very thick, feels like carrying my speaker cable at times but its very flexible. I am very keen on RX after what I heard in this thread and at the same time looking at CAvali liquid carbon.
Interesting. Does the Beats Audio cable have the bass pot box attached to it? There may be a narrow Q factor to the bass adjustment even if it says the boost is applied at 60 hz. I haven't bothered with confirming with tones or anything, but I do get a similar feeling. It's too bad to hear about the cable being even thicker (!) as the stock cable is already thick enough as it is. You may want to look into the ALO RX if you're looking to replicate the effects of that cable in a more pronounced way. I'm not sure that the RX is exactly "transparent" as I do get the sense that it does impart some sort of "signature" to your source that isn't originally there, but it's quite good at introducing higher levels of separation, stereo width, low level detail resolution (this thing is like a black hole in terms of air/blackness around notes), and impact. The only downside is that I do get the sense that the overall presentation is sort of U shaped, with more recessed mids, contributing to a sense of forward projection but feeling thinner and sometimes less engaging overall. The effect is most noticeable on vocals. It does remind me of the 1Plus2 presentation at times. Quite holographic/pinpoint feeling imaging though, which is pretty awesome.
