Thanks for the guidance Joe, esp pointing out the later independent claims. Also probably good to look at the granted patent instead of the patent application
Claim 1 in the granted patent is more broad than that of the application as regards high frequency drivers: the "tuned with" language of the application is replaced by the "oscillation of one interacts with the oscillation of the other to reduce harmonic distortion", which is simply what happens when you put two drivers together. But claim 1 of the granted patent restricts this to the three-way-all-duals configuration, unlike the application.
So on its face it appears claim 1 encompasses nearly any three-way-all-duals configuration. Can that be right?
I'm still confused about the exclusiveness of the high-frequency range and about single-port duals (used in a three-way-all-duals configuration).
