JDS Labs C5D Headphone Amp + DAC
- Thread starter _js_
cimbolic
- Jun 25, 2013
Okay. Thanks.
_js_
- Nov 28, 2008
Will these 2 work?
http://store.apple.com/us/product/MD821ZM/A/lightning-to-usb-camera-adapter
http://www.ebay.com/itm/USB-A-to-Mini-B-5-Pin-Data-Cable-Adapter-Male-M-MP3-DC-/280494538522
cimbolic,
Yes to both!
WinterCharm
Can you use your C5D from a desktop/laptop without wearing out the battery (i.e., will usb power constantly charge the battery, or is there a bypass circuit built in so that the battery stops charging at 100%) and then having it ready to go when you unplug for travel?
gauchotodd
- Jul 31, 2014
I'd also like to know
Smurfs2010
- May 21, 2014
http://www.head-fi.org/t/647838/jds-labs-c5-c5d-pg96-portable-amp-amp-dac-appreciation-discussion-thread
Yes, battery stops charging. See link above
texastrader
- Feb 29, 2012
Really great and comprehensive review JS, thanks for taking the time! I found your entry right as I was trying to understand the first problem you pointed out - how to connect an iOS7 device to the C5D without having 26 feet of wire and connectors sticking out all over the place. It appears you've handily dealt with the issue, which was my last reservation with snapping up a new C5D. Of course, your reports on the sound and the performance with various cans was also quite helpful as well.
Just wanted to give out a big thanks for your work - very well done!
sheldonkreger
- Sep 5, 2012
Has anybody found a nice fitting bag or case for the C5D?
Happytalk
- Oct 1, 2014
If you can get your hands on an armorskin from speck for iPod classics gen 5-7 it fits like as glove and has a low profile under you iphone or iPod. I will dig up a picture. But I posted one in the show your portable rig thread.
Alaskagriz
- Feb 1, 2015
I put mine in a small case designed for a hard drive. I think its case logic brand. The c5d goes on one side and I put my iem's on the other side. Nice way to transport back and forth to work.
_js_
- Nov 28, 2008
The Acme made Fillmore Hard Case 100 is a nice snug fit around the C5D--perfect in my opinion, but with no room for cables, adaptors, etc. It's also a very nice case. It's what I used for my C5D.
sheldonkreger
- Sep 5, 2012
Thanks! The colors are not my favorite, I'll wait and see if there are better options out there. Otherwise this will work. Cheap too!
-sheldon
sheldonkreger
- Sep 5, 2012
I'd love to find one of these, not seeing them anywhere in that size though :'(
-sheldon
_js_
- Nov 28, 2008
-sheldon
They certainly aren't conservative in their color choices, are they?!? Lol!
Happytalk
- Oct 1, 2014
