Apparently the battery in the C5 is made by a company called Cameron Sino and it's actually an ipod 4th gen
compatible replacement battery(model no. CS-IPOD4HL...doh!).There's actually some benchmark done(
[COLOR=00FF00]here[/COLOR]
) when this guy was upgrading his battery(
[COLOR=00FF00]link[/COLOR]
) of his Gigabeat F player.It's not widely available it seems but you can still find one in
[COLOR=00FF00]amazon[/COLOR] or a pricier one at
[COLOR=00FF00]BraunOni's battery upgrade.com[/COLOR].I also found a compatible one at
[COLOR=00FF00]ebay[/COLOR], so no worries at finding a replacement if you ever needed one.Cameron Sino actually makes good compatible batteries from the reviews I've read(
[COLOR=00FF00]here[/COLOR] and
[COLOR=00FF00]here[/COLOR]).
But,but,but that's not the reason why I'm posting, although good info to have! I've actually done something special for you miceblue! and it's very doable!
Ok here it comes! Battery improvement mod!
Let the pics take over then!
the original C5 batt and the adhesive used is easily removable.
yes! that's an S3 2100mah battery temporarily connected with just a sticky tape(batt side)/
connector pins(C5 side) and mounted with a small foam double-sided tape on the board.(See LED it's green!)
Very easily slides back in to the C5 case!
Enjoying my temporary mod with my old DAP the cowon D2 after all that work.
So there you go miceblue...longer battery life if you ever feel that the current one is still lacking!
Note:To make the mod permanent you have to solder or glue(not recommended) wires to the S3 battery and use a similar connector or small female pins(removable and shrinkwrap to prevent shortages) to connect to the C5,and you can search on ebay for cheaper compatible s3 battery options.
[COLOR=FF0000]Warning Update :This mod won't charge the S3 or any other battery that is not using the CSIPOD4HL battery Circuitry cause the the C5 can not detect the temperature properly.[/COLOR]
[COLOR=FF0000]Solution: Remove the S3 battrey circuit and solder the CSIPOD4HL battery circuit onto the S3 battery(Do this at your own risk)[/COLOR]
