PetSoundZoo
- Mar 16, 2013
Perhaps, I am not doing it correctly, but I do not see a plugin or addon folder. I'm not very savvy when it comes to these matters, but thank you.
I dont know if I should be saying this but, there is a way to use Jriver for free. Just install jriver with the internet connection off. When I installed it that way, there was no count-down of the trial days left.
These apps don't cost an arm and a leg, and if you are a passionate music lover who will get countless hours of aural bliss out of using one of the very best media library manager/player/DSP host out there, the amount J River charges is really negligible.
Bumpin an old thread that should continue getting more attention.
Any HD800 owners using Isone that is kind enough to post picture of their current settings?
+1. It took my LCD2 to another level as well as really opening up the sound stage. Once I had it calibrated to the LCD2s I couldn't listening to anything without having isone in the chain.Bumpin an old thread that should continue getting more attention .
I use Beyer T1 so sorry can't help but I am happy to see this thread get some attention. I never thought this program got the attention it deserves. I use this program every day. Sometimes depending on the material I only use the crossfeed and sometimes I use the full system. Amazing dsp when used properly.
Technically the TB isone is the better version allowing you to calibrate things to a tee. I use the isone pro only because it's easier to use while still providing a "wow" effect. The "wow" effect can be taken to a higher degree with TB isone if you are willing to spend time with it and/or have knowledge with crossfeeds.Which version of Isone is recommended? TB? Pro? Other?
And which version of JRiver for MacBook Pro is best matched with Isone?
Thanks
Thanks
Not using JRMC19?
Thanks
TBIsone offers some preset features that are really nice and easy to use. You can choose different levels of crossfeed with a single click. You can also choose different profiles that are preset staring points for tuning in the program. I had the earlier version and I find this one works even better and easier to get great results. I use JRriver 17 and it integrate perfectly. I had 18 and went back to 17.
