Lunatique
- Mar 7, 2008
Well I tried it out again, this time TB Isone rather then Isone pro, but the result is pretty much the same.
Listening to the file you sent, I see what you mean, but I don't need Isone to get the illusion of speakers, Isone basically just places the "virtual speakers" closer together.
It messes up my headphone frequency response and clarity as well, I get less bass, the bass sounds muddy, the mids get recessed and I get blurry fuzzy highs.
I tried the settings you recommend and I tried to see if I could improve it a bit, but in the end, it just sounds monophonic and dull.
I think you might have to unlearn some of the biases and misinformation you've picked up in your life so far, and learn a bit more about the science of acoustics in order to understand and appreciate what Isone does. For example, there's no way in hell that any headphone is capable of a natural sounding stereo imaging unless some kind of crossfeed is used. It doesn't matter how the headphone is designed and how it tries to angle towards your ears or use housing that sounds more open and natural--the left and right channels are totally separated, period. It's simple science, and it's the reason why audio professionals have always advocated against doing critical mixes and masters on headphones. That is why some headphone amps have crossfeed features, or plugins like Redline Monitor and Isone exist. Crossfeeds allow both channels to feed a bit of itself into the other channel, thus mimicking how we hear speakers in real life, and Isone is a much more sophisticated algorithm that models the HRTF (Head Related Transfer Function) as well as models speaker cabinets and rooms. The result is far more realistic than a simple crossfeed.
Also, I already explained the frequency thing in a previous post, but you probably didn't read it, so I'll explain it again. You need to understand how acoustics work in real life. Any time sound is produces in a room, it will interact with the room and then interact with your head and your ears. Just by having a head and ears physically, you are already altering the frequency response of any sound that is reproduced in a room and what you hear with your ear drums is the altered version, not the version that is actually played by the speakers. What Isone does is to model that HRTF alteration realistically, as if your headphones are speakers playing in a room. The frequency response change Isone introduces is NECESSARY in order to make your headphones sound like speakers in a room and you are listening with a physical head and ears. If it didn't alter the frequency response, then there would be no emulation of HRTF, and your headphone will sound if your ear drums are just floating in a room without a head or ears. That would be far less natural sounding--I think you'd agree.
So essentially, what you hear through Isone is how your headphones will actually sound like if they were played as speakers in a room, and you listening with a physical head and a pair of ears. You can't possibly expect your headphone's sound to not change when you use them as speakers in a room--it's scientifically impossible.
You might also want to double-check your VST host isn't causing strange distortions. I've had that happen before. Use a rock-solid VST host--preferably one that audio professionals are likely to use.
If you want to Isone without the HRTF and room simulation features, you can simply turn them off, set the speaker cabinet preset to flat, and use it as a standard crossfeed.
I eventually settled with Redline monitor a few months back and I'm very happy with it.
For people who don't want the realism of HRTF or speaker cabinet and room simulations, Redline Monitor is a great choice, since it's just strictly a crossfeed. But considering Isone can do the same thing as Redline Monitor if you simply turned off the HRTF and room simulation and use it as just a crossfeed, while paying far less money (Redline Monitor costs 5 times more than Isone, but only has 1/3 of its features), I think Isone is the no-brainer choice. I got Redline Monitor before I had learned of Isone, and if I had found Isone first, I would never have gotten Redline Monitor.
