nick_charles
- Feb 26, 2008
I don't have one on me. I should really get around to doing one.
The math checks out, though, so as long as our understanding of the working of electricity and its interaction with materials is correct, it is a credible scientific theory.
Silver plated copper cables are unnaturally bright because the signal is split into two signals moving at different speeds through each material. Which material it travels through depends on the frequency. When this phase difference hits the speaker end, it becomes brightness due to the differences in energy between the signals.
I have tested the FR on cables made from solid copper, stranded copper, stranded silver and silver-plated stranded copper empirically (measured) , there was no notable difference between the samples I used, all had essentially (+/- 0.006db) a flat FR from 20 - 20K - the silver was not brighter at all let alone unnaturally so in either plated or stranded form. I suggest the samples in which you found such unnatural brightness are faulty.
The phase differences (group delay) you speak about are not humanly detectable until they hit about 5 microseconds (under extreme lab conditions i.e an anechoic chamber at 3500hz a range where the ear is very sensitive) . A 10ft cable will give you a 2ns group delay at 20K, a 50ft run of cable will have a group delay of about 209ns at 20K which is a bit over 1/24th of this value, all of this at 20K where the ear is far far less sensitive ---- to say this is not humanly detectable is an understatement. To get a detectable group delay from a simple cable requires a cable of prodigious length. See Floyd Toole's work on this.
