Originally Posted by Audio-Omega /img/forum/go_quote.gif
So balanced has twice the voltage ? Does that provide better detail / resolution / bass ?
Well...yes but no. If you just wanted twice the voltage, you could turn the volume knob up (like
mulveling said). With ideal / perfect equipment, you could do that and it would work great. But it's not perfect.
A speaker is just a device that you run current through, with a positive lead and a negative lead. For a normal amp, you put the signal +V on the positive lead, and use GND for the negative lead. One note is that we assume GND is constant, but it never really is quite so. Another is that the results are limited by how quickly the change in the signal on +V can be effected.
For a balanced amp, instead of calling the negative lead GND you put an inverse signal on it such that -V = -(+V). Then when you want to produce a signal, you send +V up towards
half the total potential difference you want, and -V downwards towards
half the total potential difference you want.
Think of it as if you had two spheres that have to be 120 miles apart after one hour. You could send one away from you at 120 miles per hour, or you could send them in opposite directions at 60 miles per hour. You could wrangle the first option with good enough equipment - but it is much, much easier to do the second. Balanced operation allows us to achieve much better results without using parts that are obscenely more expensive and difficult to produce. (Of course, balanced is still really expensive...)
