dippyboy_87
- Feb 10, 2009
Yeah I'm very much satisfied with the battery life. And its stable so far for me as I didn't encounter any crash with the latest build. No not even once.
I plan on purchasing a 240gb Classic off ebay soon, but I'm unsure if I should get the 5.5G or 7G. I've read some people say the 5.5 has better sound quality while others say the 7 has better sound quality. I was going to get the 5.5 because I saw it was compatible with Rockbox but from what I understand in this thread, Rockbox can now be used on 7G using something called EmCore, is that correct? Does anyone have a recommendation of which ipod I should get, the 5.5 or 7? Is rockbox stable on the classic 7G and is the sound quality on the 7G as good as the sound quality on the 5.5G? I'm leaning towards the 5.5 now, but can't help but wonder if the 7G might have better technology/features.
Any advice would be very much appreciated!!
I certainly hope not. I dont see how it is difficult to NOT pull the cable out while the thing is flashing. Besides, even if you get horrible issues with the firmware and stuff, the disk mode is built into the ROM, which by definition cant be destroyed. No matter what you will always be able to get back to square 1 by booting into disk/recovery mode and restoring with itunes. Theres stock ipod firmware, disk mode, and a specific recovery mode that the ipod can be in. That specific recovery mode is what i'm refering to in this post.
Hm, strange.. I was about to try your suggestions, but now my computer won't recognize it.. As a disk, that is. It still makes those sounds whenever I pull the cable off, but I can't see the actual drive itself, or make a safe eject.. The ipod goes into USB mode, though. Thanks for your help so far, ^^
