...perhaps I could use the shortcut file to view the graphical EQ curve. (When showing off my rig to friends and peers, I like to show them the extreme EQ curves.) What text should I enter into the shortcut file to view the graphical EQ directly? Or maybe, instead, I'd prefer the shortcut just to take me one menu out from there -- just to the equalizer settings menu. This way, it's a lot easier to view the current settings than to navigate through all those settings menus.
I just now played around with some things in Rockbox, tried different ways of writing the code in the shortcuts.txt file, and re-read parts of the Rockbox online manual, and it looks like Rockbox doesn't give me the option to jump directly to certain menus if there isn't a direct numeric value setting for that particular menu.
But I was able to write the shortcut file to allow me to jump directly to the balance, brightness, and EQ precut menus, since those do have direct numeric values that can be set. So I wrote my shortcuts.txt file (which I inserted into the .rockbox folder) with the following text:
[shortcut]
type: setting
data: balance
[shortcut]
type: setting
data: brightness
[shortcut]
type:setting
data: eq precut
So on the main menu, now, I can go to the "Shortcuts" option and find those three settings right there, which is a lot more convenient. But I still like having my simplified "Screen Brightness" folder in the Files menu, though, for even more convenience!
Personally, my Files menu has 4 main folders now:
EQ presets 1
EQ presets Cayin C5
Joe's Music Collection
Screen Brightness
Works great....
