Whippler
- May 13, 2012
So, r859 and latest build of rockbox? Anyone else knows about less power hungry versions?
Thank you
yah r859, and rockbox version is: de417ab-140922
Thank you
I am frustrated with the USB connection problem, my iPod always is not recognized by computer.
Hence, i have to reboot the iPod and try to connect again.
I found that there are 2 commits about ipod6g on the rockbox git.
ipod6g, ata: Fix audio drop off while waiting for ata not busy
iPod Classic: Fix bidirectional clickwheel communication.
I have just compiled it with PID/VID modification.
https://www.dropbox.com/s/hmjnacgvmkqgkyi/rockbox-f313253M-141002.zip?dl=0
Thank you!
Edit: maybe it's just me, but the LCD screen stays on when the hold switch is enabled
Thank you!
Thank you!
I have just compiled another version which exclude the commit below.
It seems that it broke the hold detection.
https://www.dropbox.com/s/wy26kk3njkmmr30/rockbox-9b57610M-141003.zip?dl=0
Thanks again. With the previous build, the Classic was recognized immediately the first time I connected it, but subsequent attempts all failed. Either the device was not assigned a logical drive letter, or it was, but I couldn't browse it. I tried resetting while still connected (always works on my laptop), safely removing, which then required a reset, as it was stuck in USB mode, then reattaching, but no luck. I did not try rebooting the PC or try a different USB port. Curious to see if this new build behaves differently. If not, I'll try the much older previous build I'd been running.
Thanks for your feedback.
I have just tried to connect my iPod Classic with this build on Windows 8.1/Arch Linux/OSX Yosemite.
I can connect and eject it repeatedly without any issues on each OS mentioned above.
The drive is being recognized and works properly.
I hope that the problem is solved in this build.
I installed it yesterday on my ipod 5.5 80gb, i installed the 7c20d8f rev but i have a lot of problem with it. the database is really slow, it take me 20sec just to enter in a folder and a lot to start/stop music and after i took off the pc the disk is constantly spinning and i can't do anything or the player freeze :| i'm thinking to change to the standard build and see, it's impossible to use. anyone have some advice for me? thanks
Wait, this build for the iPod Classic (6G) actually works on your iPod Video (5.5G)?
Completely delete any existing Rockbox folder on your iPod and place one of these builds.
