RickB
Don't know if it has been posted yet, but: http://www.macrumors.com/2015/11/27/iphone-7-no-3-5mm-headphone-jack-lightning/
That may be what gets me back to Android.
As long as there will be a lightning to 3,5 adapter with DAC I don't think there will be any problem. It's even possible, depending on the DAC used, that SQ will be higher...
OMG, I can just see audiophile companies coming out with fancy DAC lightning adapters for headphones...
Wouldn't the iPhone draw more power if earphones are plugged into the lightning connector unless Apple use a bigger stronger battery in the iPhone 7. If this is the case then it's a bad move from Apple and I'm afraid my iPhone 6S+ will be the last iPhone I will own as I use my iPhone mainly for listening to music, making music on the go and the internet.
TBH i'm more worried about iPhone 7 shielding than about anything else. I'm 100% sure that i will be able to use my SE846 out of iPhone 7 one way or another. Buzzing will prevent me from doing so hence it's my main worry atm.
