FWIW, I will mention that the JDS Labs C5D Amp / DAC combo which uses the CCK (actually called the "Lightning to USB camera connection cable) and USB Audio Class 1 sounded very good to me, used pure digital out from iPhone Lightning connector, and more importantly, had a "battery" mode which reduced the power draw on my iPhone. In my experience, though, it still DID draw down the battery a bit--about 1 percent per song, which is a runtime of approx. 400 minutes, significantly less than the native runtime using the HO. Plus, you also have the added PITA of having to go from CCK to micro-USB cable, with the CCK terminating in a huge female USB end, mating with a huge, fullsize male USB end, which then goes to the C5D.
In something like the Fostek or Sony or the HiFi M8, you just use the Lightning charging / synching cable--and there are off-the-shelf short ones available--to connect to your amp/dac combo unit. Much more elegant.
I sold my C5D because I felt the improvement wasn't enough to justify the extra hassle and the SQ out of the 5S was so good with my ER-4S's and HD595's. But if I ever decide I want a portable Amp/DAC again, I will definitely go for a CEntrance HiFi M8. It can drive most anything and is a registered Apple MFi device. I figure in for a penny in for a pound. Or nothing. Which I am quite happy with. LOL!
