iPad to Support USB Audio Interfaces via Camera Connection Kit?
Apr 30, 2010 at 4:50 PM Post #76 of 454
Originally Posted by LintHart /img/forum/go_quote.gif
Can someone please test if applying a EQ setting like Bass booster will distort the music to no end like when using HP out or LOD? Im hoping that it will provide a cleaner improvement seeing as a high quality DAC should be able to work with it better.
cheers
Lint
It's not the fault of the DAC. Apple don't apply replaygain or lower the output volume when the EQ is applied. And there is no overhead.
Good or bad DAC has no bearing on the distortion. It is simply 100% a bass ackwards EQ design. Sadly. If they had one working (with customisable EQ settings), I'd not bother with Rockboxed clips and Fuzes.
May 1, 2010 at 9:43 PM Post #77 of 454
Any comparisons between PC->Dac/Amp and iPad->CamerKit->Dac/Amp in terms of SQ and volume level?
May 2, 2010 at 12:49 AM Post #78 of 454
Originally Posted by gopack87 /img/forum/go_quote.gif
Regarding volume control: when using with an external dac/amp connected, do you max out the volume on the ipad and then adjust accordingly on the dac/amp?
The general consensus is that you keep the volume to the minimun on the DAP/ipad/ipod and use the amp to adjust the volume. This is because your external amp most likely will have a better amp than the device you are using.
May 2, 2010 at 1:08 AM Post #79 of 454
Given the title of this thread " iPad to Support USB Audio Interfaces via Camera Connection Kit?",.. would your suggestion be the case with USB out also? I presumed that the Camera kit would allow one to by-pass the internal iPad AMP and DAC. I'm I wrong in this?
May 2, 2010 at 1:33 AM Post #80 of 454
Just got my iPad Camera Connection Kit. Works great with the USB in of my iBasso D1.
May 2, 2010 at 2:04 AM Post #81 of 454
Thanks for pointing that out. I totally goofed. Yes, you are right, if you use a LOD for line out, you are bypassing the internal dac/amp, and you won't need to worry about volume as the only volume control will be on the external amp.
May 2, 2010 at 2:09 AM Post #82 of 454
LOD = bypassing internal amp.
Camera kit = bypassing both DAC + amp.
May 2, 2010 at 2:17 AM Post #83 of 454
Yes I knew that. That is why I refer the "LOD" as bypassing the internal dac and amp. I am only using the term LOD in the general sense in this case. But what you said is right. LOD as in ipod or general DAP only bypassing amp and a digital line out will bypass dac and amp. Now, is there any other correction from anyone? Please feel free to pile on.
May 2, 2010 at 4:41 AM Post #84 of 454
Jalo, LOD--line lout dock, that is--has traditionally been reserved for analog line out docks, for that's all that been available. Therefore, your connotation is rather poor and best avoided.
Sorry, I couldn't help piling on.
May 2, 2010 at 5:46 AM Post #85 of 454
You are welcome. You are right. I was just careless with terms.
May 3, 2010 at 7:13 PM Post #87 of 454
The TTVJ Portable w/ dac also works spectacularly. Another interesting feature is that the main headphone jack continues to work, so you can use both at the same time, to allow 2 people to watch a movie on a plane, for example.
May 3, 2010 at 7:17 PM Post #88 of 454
How does it compare with the PC in terms of sq? Are you getting the same volume level as with the PC?
May 3, 2010 at 7:20 PM Post #89 of 454
That's great to hear as I just received my Ipad and camera kit and have the TTVJ slim amp/dac arriving later this week
