Paulus XII
Formerly known as FW214b
Got them today. The experience via Bluetooth is very disapointing. Volume is too low, there's almost no bass, they sound muffled... Well, going to get a DAP now, because this IEM was not made for BT... Sad.
I tried them with aptx HD BT and while it sounded decent it's clearly the worst way to use these headphones, sound wise.
Yeah, but personally I can't really imagine a situation where I would need to go wireless when I can have the better sound wiredNo doubt about it! Still, I’m glad it’s there as an option!
Do you mean the ear fins?Someone in the isine 20 thread suggested using both the over ear hooks and the new fit tips in tandem. It's an excellent combination and works best for me as compared to each as a standalone option. Extremely stable and comfy.
YesDo you mean the ear fins?
I'll try it some time, but the ear fins alone were very uncomfortable for me and didn't keep the earphones from falling.
I am similar to you. Fins didn't work. Hooks are better. By combining the two it seems to take some of the pressure off your ear from the hooks so definitely give it a try.I'll try it some time, but the ear fins alone were very uncomfortable for me and didn't keep the earphones from falling.
The ear hooks are better but also uncomfortable after a while.
Cool, thanksI am similar to you. Fins didn't work. Hooks are better. By combining the two it seems to take some of the pressure off your ear from the hooks so definitely give it a try.
I tried the BT cable once for about 5 minutes. Back in the box it went. My phone doesn't support aptxhd (damn you samsung) but I think if I HAD to go wireless I'd use my ES100. But I'd probably just use my MW07 and call it a dayYeah, but personally I can't really imagine a situation where I would need to go wireless when I can have the better sound wired
