timiambeing
- Feb 12, 2013
It’s not worse, but rather a little different.
Of course you have a little more volume range with SE depending on the headphone sensitivity, but a negative preamp value would also make the XLR output very usable for more sensitive headphones and give the needed headroom for potential EQ adjustments (to prevent clipping).
Here is a video of a DAC/AMP shootout mentioning the difference between SE and XLR for the EF400:
One important fact is, that the output impedance is by far the lowest with SE/6.3mm. So with low impedance cans it is best to use this port.
In fact it could very well be that the perceived difference in sound between the two ports is just a result of not testing with correct volume matching.
Yes I just noticed this review last night, been waiting for my usual guys to get the EF400 for review! I also saw the impedance figures mentioned here somewhere for the various outputs, curious how each port has a different matching characteristic - but hey, if it sound as good as everyone says who’s that bothered! I’ll get a balanced cable and try both, only way really…
