Hi guys, thought I might post my question here and provide a little background info to shed some light.
I am a Shozy owner and love it, prolly my best sounding DAP to date. It does well for me at work (i'm a cleaner) so blind screenless operation is fine. But i want something like the Shozy sound but with a screen that can
display tagged lyrics and allow for
song rating (for times commuting on a train etc)
My smartphone is a Galaxy K Zoom, and poweramp can do both these things (lyrics and song rating), however my HO on the K Zoom is dodgy, it seems a tad too tight, every jack I insert gets pushed out by half a mm etc (after a time), even a slight jolt or twist and the connection is lost
So here I stumbled upon this fella and thought it might do the trick seeing as I can use the usb micro to hear sound and avoid the HO out altogether.
But there is one last problem...
Android is too quiet for me, on all devices I have tested (Nexus 7 2012, Xperia E1, K Zoom, Note 2) etc etc. I had to root the Xperia E1 and change the mixer_path file data to lift off the volume limiters that seem globally applied to all android devices... it really sucks to do this but once done the device sings much better.
The K Zoom doesn't seem to have a great safe root process, or at least I'm not willing to risk it (especially if it may compromise the camera quality), so I'm hoping that the Cozoy will allow for greater volume than what the HO is able to do...
I understand I could amp also (to the Cozoy), and this maybe something I have to consider, but now the K Zoom is becoming quite a big bundle of wires and devices to carry around...
Please understand, I am not after crazy volume levels, DAPs like Sansa and Cowon are able to reach adequate volumes, and once u lift off the volume limitation values on Androids mixer_paths, it doesn't mean it goes dangerously crazy loud, it just meets similar volume levels to what Sansa, Cowon, Shozy etc are able to.
Besides, I prefer to replaygain my music to 89-90db thereby when shuffling I don't have to play with the volume control as much (but this act can lower newer recordings by a good 7db etc).
I'm just trying to ascertain if the Cozoy is the right thing for me, or whether other things like this exist but will provide a better volume than what the Cozoy can output. It makes little sense to spend $199AUD on this, and have to get an amp as well if there is one device that is perhaps slightly larger but will do the task better for me and keeps everything less messy (cable and device wise).
Cheers for any advice
Bruce
