Introducing Shanling M3 Ultra - New Generation of Compact Android Portable Player
May 4, 2023 at 8:22 PM Post #182 of 235
No Apple Music working since update!
Ps.started eventually, dap is mega slow😰😂
We are not seeing any complaints about the Apple music working slowly? We have just been at few events in Japan and running Apple music without issue.
May 6, 2023 at 1:31 PM Post #183 of 235
It got sorted on its own, not sure what is was, likely Apple between devices issue, it wouldn't respond for a while, it was temporary after the 1.3 update
Jun 13, 2023 at 10:54 PM Post #184 of 235
Couple of questions:
Does the AGLO feature mean streaming apps (incl. Apple Music) bypass Android re-sampling?
Does it do Apple Music offline content?
Does it have coax output (either via USB or 3.5mm)?
Jun 14, 2023 at 1:50 AM Post #185 of 235
Yes, it bypasses Android re-sampling for all the apps
Yes, it works with Apple Music in offline
No coaxial output
Jun 19, 2023 at 2:47 AM Post #187 of 235
does this sound a lot better then m3x or a LOT? also is m3u warmer then the m3x signature wise?
M3 Ultra is warmer in tuning than M3X and we consider it to be upgrade in the sound quality overall.
Jun 23, 2023 at 2:06 AM Post #188 of 235
Neutron on the Shanling M3U is definitely winning. Not sure what kind of sorcery they pulled to extract even more out of this device but they did it.
I’m having an issue with Neutron on my M3U, and wondering if anyone has had a similar problem or any ideas on how to fix it? If I rotate the volume knob even a single click while the screen is on, it crashes the app. Every time. If I turn the screen off, I can adjust the volume using the knob, no issues at all. See my videos below. I have uninstall/reinstall’d the app many times, and even factory reset the device a couple of times. Still the issue persists. It’s not a deal breaker for me, just a bummer because I love Neutron.
Jun 23, 2023 at 10:54 AM Post #189 of 235
I have no problem with the Neutron v2.22.2 on the M3U v1.12. (I bought the Neutron license directly from the developer via PayPro.)
Maybe Neutron settings (or other apps installed) are causing the issue?
Is the "Hardware Volume" setting under "Audio Hardware" in the Neutron settings turned ON? (I have it turned ON.)
Did you try the Neutron with the default settings? (Uninstall Neutron then delete (or rename) NeutronMP folder on the root of the internal storage if it's there, and re-install Neutron again.)
Jul 11, 2023 at 4:38 PM Post #190 of 235
@Shanling I seem to have an issue with displayed battery percentage in the OS while the device is charging.
When I charge the device, the red LED lights up and the lightning symbol appears on top of the battery symbol.
However the displayed percentage stays the same for a very long time until a certain point when it does start to register a change in percentage.
If I restart the device, the percentage is displayed correctly but then gets stuck again at the displayed percentage.
Same thing happens if I charge it while turned off.
Also, is there any way to know if the device is fast charging (QC3.0) ?
I tried a QC3.0 compatible charger but there is no "Charging rapidly" text displayed as it is on phones.
My unit has firmware 1.1.
Jul 11, 2023 at 8:20 PM Post #191 of 235
Will report it to software team again, this is just visual bug.
You can use Ampere app to check on the charging speed.
Jul 31, 2023 at 4:15 AM Post #193 of 235
Jul 31, 2023 at 4:47 AM Post #195 of 235
Error message on local install.
On your screenshot is firmware for M9 Plus, but you are posting in M3 Ultra thread. Please which player do you have?
