You know the funny thing about the crappy UI is that I've started doing full libary shuffle and have refound favourite songs that I would have otherwise forgotten to the passage of time.
Introducing ONIX Overture XM5 - First Portable Player from ONIX
- Thread starter Shanling
I am still happy with simplicity of non-android devices for music. Works and boots up fast, screen is smaller because it doesn't need to be bigger unless people browse websites, books or game on daps. Ergonomy is the best for pocketable use and bonus on desktop use. Onix can just work on keeping everything the same just improve the sound indefinitely in future versions
(not that currently it is bad but can be always better ofcourse). Maybe replacable modules like the caying n6III but that will increase the size which I don't like on n6III
Hinomotocho
Although my WM1Z has what I deem to be a higher level of SQ, the XM5 is close to the perfect dap for me:I am still happy with simplicity of non-android devices for music. Works and boots up fast, screen is smaller because it doesn't need to be bigger unless people browse websites, books or game on daps. Ergonomy is the best for pocketable use and bonus on desktop use. Onix can just work on keeping everything the same just improve the sound indefinitely in future versions(not that currently it is bad but can be always better ofcourse). Maybe replacable modules like the caying n6III but that will increase the size which I don't like on n6III
Non-Android, booting straight up (Sony takes ages for its compulsory database check), USB-C, drop down menu, buttons on the face, volume and outputs on the bottom. Ideal ergonomics. For both desktop and pocket use, the outputs on the bottom make so much sense. I think the DX180 also has outputs on the bottom, maybe a new trend?
My wishlist would be:
Fast charge, back button on the lower part of the screen.
the ibasso, cayin and few others are putting the volume on the opposite side of the outputs which makes a bit harder to turn volume while in pocket - here in xm5 the volume and cables are basically sticking at the pocket exit so very convinient.Although my WM1Z has what I deem to be a higher level of SQ, the XM5 is close to the perfect dap for me:
ToneDeafMonk
Previously known as TheDeafMonk
One of the buttons is programmable mine is set to screen on/off not sure if there is a back function alsoAlthough my WM1Z has what I deem to be a higher level of SQ, the XM5 is close to the perfect dap for me:
Hinomotocho
I just checked quickly and it has 'return to main menu', so perhaps not an actual back/previous screen function (I haven't tried). I had opted for that to be assigned to the screen option as I had thought that it may reduce any wear on the volume dial.One of the buttons is programmable mine is set to screen on/off not sure if there is a back function also
It's not a biggie, i just find with my smaller hands it's a bit of a stretch. Coming from years of Sony Walkmans I'm used to it being bottom left corner (I'm a lefty).
chaotic_angel
Hello @Shanling is there any way to change the line out in XM5, I found the 4.4 line out sound to be distorted, when connected to AK PA10
You can run it in HP out and lover the volume if it seems the balanced line-out is too hot for the amp.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
chaotic_angel
thank you for your reply, by running it from HP Out meaning it is double amping?You can run it in HP out and lover the volume if it seems the balanced line-out is too hot for the amp.
XM5 does not have dedicated line-out circuit, line-out mode is just software setting. Only difference between LO and HP mode is if the volume is locked at line-out voltage or not.thank you for your reply, by running it from HP Out meaning it is double amping?
Wubby
- Aug 3, 2009
does the xm5 come with a screen protector already on it? The glass seems kinda raised, but the manual says 1 screen protector included and that was in the box separately.
XM5 comes with screen protector applied, there is extra one in box.does the xm5 come with a screen protector already on it? The glass seems kinda raised, but the manual says 1 screen protector included and that was in the box separately.
Wubby
- Aug 3, 2009
awesome, thank you!XM5 comes with screen protector applied, there is extra one in box.
Rockcoon
- Feb 23, 2015
@Shanling, is it possible to make equaliser work not only with 16/44.1, but higher quality tracks?
It has been like this in our system since 2018, so far we got no improvement on it from our software team.
