OneEyedHito
Currently have the Noire X on head.....will have listening impressions after a few hours:
Only initial things of note are the clamp force is a 4.5 on a 5 scale (with 5 being TOO MUCH FORCE) for a 7⅜" (18.73cm) hat size if that matters, the physical cup size is a better fit for me than the E3 though, those always caused a bit of pressure on jawbone that bothered after a bit, these have that but they hang down a bit lower on the jawbone so once clamp force breaks in it should be better.
The pressure relief ports are located on the outer edge of cups instead of directly in the Gorilla Glass like the E3, and some precut satin or matte clear wrap pieces to go over the gorilla glass would find their way into my cart for certain and as an aside about how I treat newly unboxed headphones I didn't even look at them before putting on my head but it would help with fingerprints for sure, looks don't usually matter to me at end of day.
