Feb 16, 2025 at 3:29 AM Post #871 of 1,188
One of my favorite things about being a DCA club member is the amazing discounts they provide. I jumped on the Noire X the moment it announced and had it rotating along with other headphones but when I plugged them into the LAiV stack they turned into something even more amazing!
Fantastic synergy that enhanced all of the Noire X strong points. Wider sound stage, deep reaching bass and gorgeous mids. Both Stealth and Expanse sound great on it too, but the Noire X has something special to my ears with this combination.
Feb 16, 2025 at 3:30 AM Post #872 of 1,188
Two weeks passed since i placed my order.
Can't wait to get these on my ears.🫣
Feb 16, 2025 at 7:14 AM Post #874 of 1,188
Feb 16, 2025 at 11:37 AM Post #876 of 1,188
Is anybody using EQ Settings with Dan Clark Audio Noire X?
THX
Torben
Yeah, I am finally using the same EQ than Amir plus a subbass lowshelf.
That would be this:
And a lowshelf, 60 Hz, +1db, Q 0.7
Feb 16, 2025 at 12:16 PM Post #877 of 1,188
Feb 16, 2025 at 3:02 PM Post #879 of 1,188
Regarding blocking out ambient noise, I find that noire x as good as my sony ANC headphones. It's pretty close but because of the stellar sound quality of the noire x, I don't find myself using the Sony much anymore. Also, I don't find myself needed to jack up the volume to help with outside noise. Just listen at my normal level and all is good.
Feb 16, 2025 at 4:18 PM Post #880 of 1,188
How does the NOIRE compare to the NOIRE X in this regard? Any chance you can show the graph for each on the same chart?
Similar. NOIRE X may have more isolation than NOIRE older than a year or so simply because the newer ear pads use a slightly denser foam, but it's on the order of 1-2 db and when the pads are replaced virtually the same.
This is fantastic info, which I believe should be supplied for all closed back headphones.
I assume the attenuation works equally both ways; ie, so that others aren't disturbed by someone using the NX? (My primary use case for mine is for listening within a shared office space, when open backs are not an option.)
Yes.
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
Feb 16, 2025 at 5:39 PM Post #881 of 1,188
THX :-) Why did you add lowshelf, 60 Hz, +1db, Q 0.7?
Torben
I just like it better that way.
I listen to rock, progressive and metal, these are styles where there isn't much sub-bass, and headphones usually need a little more support in that area to sound a little warmer, with more depth, and more pleasing to my ears.
Feb 17, 2025 at 12:42 AM Post #882 of 1,188
Loxjie D40 Pro.
Finally enough power. Now I am satisfied.
Feb 17, 2025 at 2:28 PM Post #883 of 1,188
Has anyone been able to compare the Noire X vs. a member of the fostex th/tr line? I have the Fostex TR-x00 Ebony headphones, and I'm considering upgrading to the Noire X. But i wanted to check if anyone has made that comparison here? I checked the search, but didn't see this comparison yet.
Thank you in advance!
Feb 17, 2025 at 2:39 PM Post #884 of 1,188
I had the Ebony. Great headphones!
The Noire X is a huge upgrade in all areas.
Feb 17, 2025 at 5:40 PM Post #885 of 1,188
I have had the TH-X00 (I didn't like it) and the TH-610 (I liked it very much), and the Noire X is some steps above the TH-610.
I sold the TH-610 some days after receiving the NX, because I don't need two closed back headphones, and I knew I wasn't going to use the Fostex anymore having the NX.
