Introducing NEO iDSD2! The world's first lossless Bluetooth DAC/Amp...
Jun 19, 2024 at 11:45 AM Post #286 of 409
Is it possible to set in the menu that the Neo two signals are only used by the xlr or RCA output, and disable the headphone output so that the headphones plugged in don't sound at the same time?
what exactly does volume sync set?
On The NEO iDSD2 when headphones are plugged into the port it auto-disables the outputs on the rear (No Signal)
Hope that helps!
Cheers!!
PS I will have to look up Volume Sync I have never personally used it! Will Post back unless someone else chimes in for you.
Jun 19, 2024 at 12:01 PM Post #287 of 409
Hope that helps!
Cheers!!
do you have to plug the end of the elite 15v lps cable into the neo? I saw an unboxing video earlier and there was some kind of dc converter in the box, should it be used for neo, or what is it?
Jun 19, 2024 at 12:03 PM Post #288 of 409
Yes directly from the Elite into the NEO.
Converters are provided for use with different units and configurations.
Cheers!!
Jun 20, 2024 at 8:25 AM Post #290 of 409
the power connector of the neo idsd2 has positive polarity, right? the end of the ipower 2 and elite default connector also has positive polarity, right?
The webpage for the power input defines it as follows...
DC 9V/1.5A - 15V/0.9A (centre +ve)
For any further info, it's best to open a support inquiry for specifics.
https://support.ifi-audio.com/
Cheers!!
Jun 22, 2024 at 3:11 PM Post #291 of 409
What is the latest firmware currently? If I enter my product number on the Ifi Audio page, it throws up two drivers for Windows. Do I need to install both of them? 5.12 and the larger numbering path as well? and there is a Bluetooth and xmos firmware, do they have to be installed as well? ifi nexis Which firmware are you installing? @iFi audio @Mr BubbaHyde
Jun 22, 2024 at 6:13 PM Post #293 of 409
First, I finally managed to listen to my new system(iem).. Tidal — LUMIN u2 - viablue nf75 - ifi neo idsd 2 - ipower elite - eletech ode to laura - fir audio xenon 6 . It was a captivating experience, I felt this a long time ago, that the music completely penetrates my soul with the highest level of musicality, naturalness, smoothness, the music simply flows and massages my hormones of happiness. It is so pure, so intimate, it penetrates so deeply into the soul of the music, and at the same time preserves high technical knowledge. YES, the bass.... overwhelming dynamic speed, but also heavy and punchy, and its texturing is a world champion.
Jun 24, 2024 at 8:06 AM Post #294 of 409
It would be interesting to have a tutorial for the sequence after pressing the update button.
I will see if they can post something, and check if there is a YouTube video!
I believe you just select the "update" version and start the process.
Let me know if there are any issues..
Cheers!!
Jul 10, 2024 at 12:09 PM Post #296 of 409
Did you get any information?
No, they did not post a video of the upgrade process as they felt it was pretty straightforward, sorry...
I will attempt to make an Upgrade video and post it to YouTube if I can squeeze it into my schedule, nothing fancy just a quick tutorial sort of thing.
Cheers!!
Jul 18, 2024 at 4:11 PM Post #298 of 409
I would like to buy it, but first I need to know this... does it work well if I use the smartphone as a USB source? (Local files and Qobuz with Usb Audio Player Pro)
There should be no issue using this as long as you have the appropriate cable for the connection!
Let us know how it works out for you as I don't remember anyone giving impressions on this type of connection, but there have been some using DAPs of various makes.
Cheers!!
Jul 18, 2024 at 4:46 PM Post #299 of 409
Cheers!!
I have the Zen Dac V2 and often use this type of connection.... it works very well.
