M4W is meant to be used on, as most users (and many here) will want Bluetooth wireless use as the main event. In that case, it makes sense to have the headphones sound as good as they can while active as passive-mode listening is a fringe case. M4W sounds best while on for certain.
I'll get some more clarification on this and understand the scenario, thank you for the detailed description. For everyone reading this thread, here's my "best option until..." take. First a quick primer:
- M4W, through the app, can utilize ANC in 2 ways: Adaptive (set and forget) and "blanket" ANC (strong no matter the environment).
- Both versions of ANC work in tandem with the Transparency feature. You can blend the amount of transparency you want via the Smart Control app or the gesture control pad on the hardware
- To adjust transparency amount via the hardware, pinch "open" (like zooming IN on a smartphone) in either ANC mode
- From MOST ANC/LEAST TRANSPARENCY setting, you can pinch open 5x to reach LEAST ANC/MOST TRANSPARENCY
- To adjust transparency amount via the app, use the slider (Adaptive mode only)
To achieve "least amount of ANC without too much transparency" (sorry I don't have a shorter name), turn ON adaptive, then slide your ANC setting to the middle. Based on what your own sensitivity you may want to adjust slightly. I've attached a screenshot
- For non-Adaptive ANC mode, there's a middle setting but not available via a slider (hardware pinch only)
- If you're using hardware gestures only, an easy way to get your bearings is to pinch open 5x, then start pinching closed until you get the balance you like (3x is great for office use, IMHO)
Again, while this is not the same as simply disabling ANC while retaining active Bluetooth and ZERO transparent hearing mode, but is close. More to come and I'll absolutely send this along to the team for a closer look. Quick reminder to update your firmware, as a new release is out 2.6.13
Thx again for the feedback everyone!
The screenshot
