gto88
- Dec 11, 2014
received my CL2 bought on EBay, but it is a defeat, returning it.
A "defeat"?received my CL2 bought on EBay, but it is a defeat, returning it.
It is damage no sound at all, I cross checked with my other iem with same cable.A "defeat"?
Did you not like it, or was it faulty?
Oh dear, that's not good.It is damage no sound at all, I cross checked with my other iem with same cable.
Then I checked cl2 connector, it has no pin inside.
Seller claims it is new other, but the box has amazon warehouse tag...
just use simple crazy glue. I had to do it on one side, and it became good as new. I think the mmcx connector is very tight, and if you pull on the cable instead of using fingernails, the pressure on the housing cracks the glue.Hey everyone, Last week I was inserting (gently twisting) my CL2s into my ear and the case split and separated enough to scratch my ear, I took a look and sure enough it split where the two halves connect.
I purchased my set from a fellow Head-Fi’er in 2019 and assumed the warranty transferred - It does not. I reached out to RHA and they were polite but not helpful, they told me to go get them repaired at a local shop - I’m not sure who in my area could put a delicate planar IEM back together without damaging the unit.
I really love this set of IEMs in spite of the weird tuning, I find them to be exceptional and impossible to replace at this price point.
Has anyone else experienced this? How were you able to repair them?
Just line the outside edges, and clamp the shell for a bit.No risk of damaging the internals by squirting crazy glue into the shell and clamping? I haven’t changed the cable on mine since I got them, so it wasn’t caused by a cable swap - although I do recall the connector being tight.
How would you describe the sound? Compared to stock...Just got my new (used) 1950s cable and paired it with my CL2... Of course, it sounds phenomenal....
Utterly no comparison... Quantum differenceHow would you describe the sound? Compared to stock...
Enjoy it.Utterly no comparison... Quantum difference
