sunneebear
- Jul 29, 2002
Guess I may be the closest to your answer. I have the D3 which if I remember correctly some say sound better than the stock D10. My memory could be wrong. I also have the A1000X which is the W1000X without the wood. The D3 is a powerful portable amp. 42ohm is no problem for it. Matter of fact, it is a lot more stronger than my Headphonia or Xin Reference. Though I enjoy all three amps, the Headphonia sounds good but IMO is not in the same class as the other two.
Good recording classical and jazz is a hit. The mids are slightly forward but sill sounds good. Only old recordings with poor dynamic range makes the mids and vocals a bit annoying. J-Pop female voices are extremely annoying, way too forward, with most headphones I think.
I believe you will enjoy the W1000X with the D10 but a good home amp will make the ATs really shine.
